RE: Ofna Truggy Question?
50 tooth spur gear and a 14-17 tooth clutch bell would work but what you have to do is change the front and rear diff. gears to sute the tall tires so you dont burn clutches i converted my buggy into a truggy and stock buggy ring was 45 tooth and pinion was 15 I went to a 50 tooth ring and a 10 tooth pinion with a 17 tooth clutchbell and a 51 tooth spur and it flys mabe monster pirite gears will fit -good luck
