RE: Mega Force Troubles
Hello Mike_p,
When you increase the rpm of the engine, does the spur gear rotate? The Spur Gear is the big black plastic gear between the engine & the gear box. If it does, then you can try tightening the slipper clutch which is the spring loaded nut in the middle of the Spur Gear.
Normanski
