Tiger 60 Continued Wing Meladrama
Item #1
I have a case of brain freeze going on, and this may sound dumb but I need to know so I can finish my wing.
When you are fiberglassing a wing together after it is complete and you are going to cover the wing with monocote, do
you monocoat the fiberglass also ( will it stick?) or do you paint it or put a protection coat of some kind on it and only
monocote up to the fiberglass? IQuiring minds want to know!!!!
item #2 I am getting ready to expoy in the the wing landing gear blocks and corresponding torue block. I notice if you
put the torque block in all the way there is quite a gap from where the landing gear block fits in. Is this on purpose or
do you set the torgue block to where the landing gear block meets it and they set the height of the landing gear block?
I am getting sooooo excited now that the wing is almost done!!!!.. I am sure will have some more questions, and I fully
now realize that the wing is everything!!!!!!!.....if it is done right the rest is easy!!!!!..(even thought I have not doe the body
yet)
Thanks for all the help so far!!!!
