RE: 8103 nightmere
One other thing to check: Pull the RF module, look into radio and check to see if the fuse is loose in the holder, this can cause a pesky problem. If it is loose, remove fuse and very gently bend fuse holder ears to make a more secure clamp on the fuse.
