RE: 29% Katana-S ARF---Aeroworks!!!
Here is the parts list from the back cover of the manual.
Hope this is helpful
29% Katana
HARDWARE PACKAGE
PACKING LIST
FUSELAGE
4 – 4/40X 1/2 SOCKET HEAD CAP - DU571 - COWL MOUNT
4 - #4 FLAT WASHER - DU323 - COWL MOUNT
4 – 4/40 BLIND NUTS - DU135 - COWL MOUNT
4 – 10/32X ¾ SOCKET HEAD CAP - DU580 - LANDING GEAR
4 – 10/32 BLIND NUTS - DU584 - LANDING GEAR
4 - #10 FLAT WASHER - DU586 - LANDING GEAR
4 – 4/40 X ½ SOCKET HEAD CAP - DU571 - WHEEL PANTS
4 – 4/40 BLIND NUTS - DU135 - WHEEL PANTS
4 - #4 WASHER - DU323 - WHEEL PANTS
2 – 5/32 AXLE SHAFTS - DU248 - MAIN WHEELS
4 – 5/32 WHEEL COLLARS - DU140 - MAIN WHEELS
2 – 3’ DIAMETER WHEELS - DU300L - MAIN WHEELS
2 – 4/40X ¾ SOCKET HEAD CAP - DU572 - HATCH COVER
2 - #4 FLAT WASHER - DU323 - HATCH COVER
2 – 4/40 BLIND NUTS - DU135 - HATCH COVER
1 – OHIO SUPERSTAR (med) TAILWHEEL
4 – 4/40X ½ SOCKET HEAD CAP - DU571 - BOTTOM HATCH
4 - #4 FLAT WASHER - DU323 - BOTTOM HATCH
4 – 4/40 BLIND NUTS - DU135 - BOTTOM HATCH
WINGS
4 – 4/40 THREADED RODS - DU144 - AILERON PUSHRODS
4 – 4/40 KWICK LINKS - DU305 - AILERON PUSHRODS
2 – NELSON CONTROL HORN - RCL70 - AILERONS
1 – 2HINGES - DU257 - AILERONS
2 – 6/32 X 1 ½ SOCKET HEAD CAP - DU317 - WING RETAINER
2 - #6 FLAT WASHER - DU327 - WING RETAINER
2 – 6/32 BLIND NUT - DU136 - WING RETAINER
TAIL GROUP
2 – 4/40 THREADED RODS - DU144 - ELEVATORS
2 – KWICK LINKS (solder) - DU305 - ELEVATORS
2 – NELSON CONTROL HORN - RCL70 - ELEVATORS
1 – 5HINGES - DU257 - ELEVATORS, RUDDER
2 – NELSON CONTROL HORN - RCL70 - RUDDER
2 – 4/40X ¾ SOCKET HEAD CAP - DU572 - STAB RETAINER
2 - #4 FLAT WASHER - DU323 - STAB RETAINER
1 – DUBRO PULL-PULL SYSTEM - DU518 - RUDDER
2 – STRIP AILERON HORN - DU103 - TAILWHEEL
