RE: Throttle curve
Yes, small percentages in the range of 5-10% or so. If the percentage used is too high it can possibly cause the throttle to increase, then decrease, then increase again. The percentage must be low enough to not cause the mix to overcome the throttle travel, but large enough to alter the curve as desired.
