ORIGINAL: rs4driver
i also am building this kit, i have it done as far as building go's, i just need to cover and install the engine and all that good stuff, took me around 2 weeks, real simple build, i enjoyed it, cant wait to get it covered and everything and get it in the air.
also, going by the pic of your landing gear, unless you added it later after you took the pic, your missing 2 wires, theres 2 more V shaped ones that attatch to the main 1/8 wire and the ends are soldered, and the middle of the wires are held with a rubber band (acts as a shock)
i won't finish the gear until after covering and painting and final fitting of everything.
i admire your ability to complete the build work on this kit in just two weeks. if only i could build that fast then i would have a much shorter "wish/to do" list.
