ORIGINAL: motoxer52
no it the cheap desigean of the where the rea arm blots go
will a gs storm pro chassis work or juts a storm
I don't know of a single stock truck that could withstand such an impact. If you were drag racing and "were goin", it's fairly safe to say you were running in excess of 40 MPH. The SUT uses 2 bolts to hold the aluminum arm carrier (one for each arm). I wouldn't call it a bad design. If they were part of the bulkheads (as many other trucks are), you would need to replace the bulk-heads as well. Either way, you'd end up needing parts.
