eclipse manual is wrong
not real familiar with the gy 240 but this should be fairly common to all HH gyros and the eclipse. I personally have the CSM 360. The servo goes into the gyro and then the main gyro lead goes to channel 4. The manual is wrong when it says 6 as this is the pitch channel. If the gy240 has a seperate plug for say HH on/off like mine i went with channel 7 and used the front switch on the tx to turn it on/off. Channel 5 is also a possibility as the gyro menu (for remote gain adj.) controlss channel 5. Hope this helped
Andrew
