RE: Quick question
Ngr1, I have tried to answer and respond to you in another thread. What are you doing with these gear and can you make the struts like Earl's? Earl made his gear shorter so that he would have room near the main spar on the Corsair. As you may know he had folding wings and the spar in this area has to be much thicker, also you have the wing locking linkage that is right in front of the main spar. I would be interested in a copy of his gear. If you kept the parts from the original set you had you would need to make the struts and buy the bevel gears. Are you making some gear or is this just for fun?
Dion
