RE: How to install servos in a foam core wing?
CA Models has the hole cut out big enough so the entire servo can be placed in the wing... which leaves only the servo arm above the wing. So what I'm thinking, is that I can sheet the interior walls, and then install hardwood blocks on the ends of the box, which allow it to screw into. Here
's a pic of what im working with....
