RE: Great Planes J3 Cub Fuselage Covering Question
The overlap won't be much, but it will be enough. Just make sure you bring the top piece down at least past the center of the dowel.
The other area to watch out for is that Spar that runs down the side of the Fuse.
try just sealing only the very edges of each side, then shrinking with a heat gun.
