RE: My very first PATRIOT!
Yeah, I am only running 10%.. The prop is an 11x7 zinger. The tank has NO airleaks. I was running the engine lastnight, and this morning I pressed in the nozzle to let the air out, it rushed out. So it held air in the tank all night I suppose. I may try and throw a 10x8 APC on it, and run 20/20 fuel. The reason I have the zinger on it is because the original owner said its good to start off with that prop. Less speed and all. Well, I will try and see what I can do. It should run with the setup I have on it now though.. shouldnt it? I will try some 20 percent fuel sometime. And a different prop. Thanks for the info.
