ORIGINAL: ZAGNUT
i was seriously thinking about this radio until i found out about its "dirty little secret"! what good is there in channel assignments and tons of mixes if they can't be set up differently for each flight mode or model memory???
the current firmware doesn't have any specific mixers for CCPM
The channel assignments and mixes can be set up differently for every model. You would never want channel assignments to change with flight mode. Mixers can be varied by switching on and off, or to a different mixer, with flight mode by assigning both mixers and flight modes to the same switch.
I don't know anything about helis but what is the Evo's template HELIccpm with support for 3 or 4 servo heads if it isn't a mixer specifically for ccpm?
There are one or two shortcomings which we believe Multiplex is addressing for a future free upgrade following on from customer comments, but you didn't mention those shortcomings so I don't think you understand the Evo.
Harry
