RE: Covering Issues
there's high and low on the gun.lol
it's not you, i've had the tip of the gun right on mk trying
to make it shrink on curves. that was the chrome film thou.
if you're using mattalic or chrome colors MK it's a bit tough.
you might have to use an iron. especailly if you trying to
rid of the sags on the rear deck. i've melted MK there many times
using the gun.
the cool thing about MK is .. you can un tac or un peel it without loosing
the color. strectch it as much as posisble by hand, re- tac
before shrinking again . triming the excess film at the head
rest area before shinking help lots.
i trim deck pieces to correct size . i use a piece of paper
as a template.
i tac and stretch as much as posisble before shrinking.
iron setting different between econokote and MK
econo= 1/4
MK = 3/4 or greater.
