RE: need advice (first kit)
I don't put anything under mine. I just stick the pins into my worktable surface (which is a solid core door). I never see the pinholes. If you want, you could lay a sheet of 1/4" plywood if you can find one that lays flat, or a sheet of foam insulation.
