Thanx a lot !!!
These are really interesting projects, but I'd like to find something commercially available, while I think it will be probably possible to order such devices mounted and ready.
Do you know if there is any manufacturer for such kind of device ?
However I will go to see on Futaba website to check it.
I can't understand what you mean with " the PC or Tx interface will need to perform all the encoding". If it is a conversion that must be done, usually there are protocols and interfaces which can do it. For instance if the trainer Jack is a serial RS232 or something (I don't know) there is a precise way to do the encoding, but it is the serial interface that does it.
What kind of interface is the trainer jack based on ?
Cheers.
Sergio
