does anyone work on ace radios anymore?
I have an Ace pro 810 reciever that just went bad, does anyone work on them anymore? this one has an intermentent problem, it quits working when vibrated, coming and going as it pleases. you can make it stop working and start working by tapping lightly on it. (btw, I lost my u-can-do 46 when it did it for the first time)
does anyone know if the pro 810 can use 5 cell battery pack? I used the 5 cell pack with it for some time but I'm still of the mind that maybe it burned something up inside causing the problem. any thoughts? (there are no obvious burned, melted or otherwise outwardly bad parts from too much voltage/heat)
thanks for any help.
Jason
