I have a problem with a mix I created in for my
Turbine jet model. I am running a crow setup and am having a problem
with the
aileron servos going beyond the atvs I set. My set up is as follows. I
am using the
normal airplane setup, not the glider program. I have mixed channel 1
aileron
Left aileron to aux2 right aileron with the trim enabled. The atvs are
set
for each channel and the work perfect. Next I created a mix with the
flap
channel. The two flaps are on a Y harness. The flaps being the master
and left
aileron being the slave. Then I created a mix with flaps as master and
aux 2 right
aileron as slave. Both mixes have an offset and the rate set and give
the
proper operation. The problem I am having is when the mix is activated
the aileron
servos do not obey the atvs I have set and bind the servos. Do I need
to go
about this a different way? Or is it just a simple problem with linking
or a
mixed \unmixed issue? Any help would be greatly appreciated
Don DeSandre
