JR Travel Adjust Problem
I am trying to install retracts for the first time and I am having major problems trying to adjust the travel on the gear channel of my JR 652. It seems that it will only go max travel. If I back the travel way down the servo does not move and as I adjust the travel up there seems to be a threshold where the servo jitters and then moves to max throw. Above this threshold the servos work in both directions OK, just max travel all the time. This is the first time I have ever used this channel. All other radio functions work as they should. It does this with 2 different retract servos, one JR and one Hitec. Is my transmitter defective or am I doing something wrong? The manual is no help. Thank-you in advance.
