RE: JR receiver question
You normally use a Y harness into one of he channels. The battery power leads for all the channels are connected so any channel will work. If you aren't using the gear channel, 5, you could use that one.
Having you use a Y for battery when you are using all the channels is fairly common on the low end. I see this on Hitech and FMA receivers I have.
