RE: O.s .70 surpass 2
It sounds like the valves need to be adjusted. You should not have backfiring problems. You said "like all fourstrokes", yet I have never had a fourstroke backfire after being adjusted properly. Only in the very early stages of breakin if you get a fourstroke too lean will it backfire, if adjusted properly. Hope this helps.
Lachlan
