Originally posted by Cyclic Hardover
I am 3/4 through my 60-90 size Cermark. I stripped the Red off completely and recovered in Monokote "Charcoal" with white underneath. I installed the Jett .90 in mine. if you go with the 91fx, you ought to install the Ultra thrust muffler also.
* I have the Little F-20 also and it is in the 120mph range. The bigger Cermark with the right engine will be around the same. There are a few modifications which are a must or tthe plane may only last a few flights before the damage show itself.
What do you consider the right engine for the Cermark F20? If it will do 120 MPH with the Jett .90 then that is what I will use! BTW, could you tell me more about the modification I need to do?
Jimmy
