RE: What Servos Are U Using in GP Christen Eagle II
According to Hitec's rating for the HS-5475 they should be more than adequate for the Christen Eagle II. Unfortunately, they are not holding up and I haven't even wrung out the airplane yet. My guess is the gears are failing from vibration, not torque. They are all failing around the neutral points, most with just one tooth on the shaft gear right at neutral.
