ORIGINAL: DTB
Ok, so basically setup the plane and with the servos installed. Install a fully charge battery and set the Tx to cycle mode and let the cycler move the servos until the Rx battery gets low.
What you are trying to accomplish basically is to put the servos to use on the ground and try to let a faulty servo die on the ground instead of the air. Hence Run In (Break In)?
Correct?
Derrick
Exactly
