ORIGINAL: XJet
ORIGINAL: fiveoboy01
SO, if this is the case, and I have a decent amount of expo dialed in, could that cause the elevator halves to rise/fall at different rates, and have one catch up to the other at the end of the travel??
Do you have equal amounts of expo on each channel?
Yes. The elevator and aux channel have equal amounts. But the subtrim on one is -10 while the other is zero.
It seems like moving servos one spline at a time with subtrim at zero, try to get the surface as neutral as possible might be the solution...?
FWIW, one elevator pushrod is probably twice the length of the other...
