Mixing elevator halves w/ JR Tx
I'm using a 9X, but am guessing my issue would apply to the 10X as well. I have a standard mix with EL as master and Aux2 or Aux3 as slave (forgot which one, and don't have it with me here at work). There's an option in the mix screen for Original or Normal, which affects how trim and expo work on the slave channel. When I select one (again, forgetting which one), the trim only works on the master channel. When I select the other, expo doesn't work on the slave channel.
Is there any way to get both expo and trim to work simultaneously on the slave channel? Also, I can't get the throws to match on all three triple rates. I tried to set it at 3D rates, figuring any difference would be magnified. When I do that, the throws don't match on the two lower rates.
Many thanks for any advice.
