Dear John,
My Evo is OK with a glow-engined model ( with conventional servo ),
so when replaced the ESC with servo everything
on the electric glider was working well.
So it´s the Hitec and MPX-synth that don´t mix well ,
and now they are of the same big corporation ...
The ESC is now discontinued. This is not a big problem to me but
I would nearly give my left arm to know the reason..
A photo included
SPECS:HITEC S1003 plus
BEC
Propeller Brake
Safety switch
Compact size
Lightweight
Operating Voltage 7.2 - 9.6 Volts / 6-8 Cells
Continuous Current 10 Amps
Auto Cutoff Voltage 3.3 volts
English Metric
Size L x W x H 1.0"x 0.9"x 0.9" 25 x 23 x 23 mm
Weight 0.93 ounce 26.5 grams
