RE: LMH Vmax 7 engine
I had my hel problem. Tank 4 or 5. I was flying and then clink the clutch flys off and spins on the ground like a top. I thought it was a joke. I walked up put it on went over to electri start and nothin turning. I knew imediatly after reading these forums what happened. I was kinda mad cause it was my first day heli flyin and it breaking wasnt even my fault. I guess ill just lube up my new engine much better. And lube it befor every single flight and after every flight. To make that junk last. Hey how are those full fusalages working on the gas 117???? Do i need to cut a hole so the cooling head can vent. I have norvel 25% fuel. How many washers should i use for break in or regular flight??
