RE: WEST 50 V1 / MAGNUM QUESTION
Sure enough... I put a spring washer under the pinch bolt nut too... only just remembered it when you mentioned it...
Side note on the fuel lines: give the brass tubes a little bend in the right direction just where they exit the tank stopper... that way your silicon lines won't have such a tight bend in them.
