RE: Whats a fast aerofoil for a DELTA
Wing...............
40" span
35" "root" chord
10" tip chord
not incl. ailerons.
im a relative novice to designing. Please point me out to stuff/ tell me wot to do to make it fly.
IF its nose heavy, i can put the servos right at the rear, and the tank on the CG (YS got a pump) and put allot to the rear, will it work???
also, had a little go on a laser arrow on aerofly pro, found that i could change the section to NACA 66-012 and it was all over the plave, fast but didnt like to do elevatr and aileron maneuvers.
What pipe do you recomend with the YS? im may get it, depending on the price, as i havent found it out yet.
thanks everyone
Ian[8D]
