RE: PROBLEM WITH JR8411 SERVO SETUP
Swap 8411 servo with another 8411 servo elsewhere on the plane. If the problem follows the servo, you have a bad servo to send back to its maker. If the problem stays at the same place or goes away, you have (or had) a binding linkage/surface. Other possibilities are unlikely.
