RE: Rossi 1.05 DF tractor engine with propeller..?
Hi der Steuermann,
Det type is double cone Type A (exactly like your drawing). The distance between the glowplug and the biggest part of the pipe is 400mm(16"). The outer diameter(OD) of the inlet is 21,5mm, thickest part (OD) id 45mm, and the OD of outlet is 12,5mm. The pipe wall is thin, less than a millimeter. I have McCoy 9 and APC 10x10 so I will give it a try next time. Thanks for any suggestions /Amir
