RE: Dymond F8F Bearcat ARF
I just ordered a GWS retract servo from [link=http://www.balsapr.com/]Balsa Products[/link]. It was $24.50 and it has 111 ounces of torque. I plan on installing that servo, along with the GP .60 size retracts that I am ordering from Tower today.
Richard, have you gotten to the pull-pull cable installation on the rudder yet? There is a balsa reinforced section near the bottom of the rudder that I assume is where you should thread the pull-pull hardware through and attach to rudder. The only problem I see, is that if you mount the hardware that low on the rudder, it seems like it will interfere with the elevator. Any thoughts you might have would be appreciated. Thanks.
