RE: Lanier Ultimate Pitts
I had a brison 2.4 and all servos in rear on mine, it balanced right at the factory 1"..I slowly moved the receiver and battery rearward to acheive the CG I wanted.
This plane flew great, and all. I did not double the ply at the cabanes without problems..I did break a few upper wing aluminum mounts in the center of the cabane.'
This plane ended up snapping in from about 30' when a friend turned his TX on without thinking.. the structure at the cabane mount stayed intact so I don't think that is needed.
I will be getting another to replace it soon...
Scott
