RE: Inflight Glitching- Due to Antenna Routing
I always wondered why there should be a correct way to route the antenna... Can't radio waves penetrate the "undense" structure of model planes? After all, they do pass through walls... and if this holds true, then shouldn't it be safe to have the antenna completely hidden within the fuselage? Maybe its for that same reason that TV antennas all point to the same direction to receive a particular station - to get the OPTIMUM reception. And when it comes to a plane in the air, anything less than OPTIMUM is not good enough right?
