RE: mitake, again?
Hi Bill,
This PC problem is endless, will have to make this much briefer than
would like to have it, maybe go to two sessions?
First pressure applied to the fuel has no effect on the head pressure for
sure. only action is to increase TOTAL pressure seen.
Fuel flow> must be known that effectively an engine is a mechanical pump whose pumping action draws fuel and air through the carburetor
where a proper 15:1 air-fuel mixture is established that fires in the combustion chamber resulting in producing power.
Will continue on another post. OK?
Hal
