PATRIOT/ SPRING AIR QUESTION
ISTARTED TO EPOXY IN THE FUEL TANK/RETRACT SUPPORT AND DECIDED TO PLACE THE RETRACT IN TO SEE HOW IT FIT. WHEN RETRACTED THE STRUT WIRE WAS APROX 7/16" BELOW THE FUSELAGE. A QUICK CALCULATION INDICATES THAT ALMOST 1 1/2" OF THE FRONT TIRE WILL HANG BELOW THE FUSELAGE. IF I RAISE THE RETRACT SUPPORT THERE WOULD BE NO ROOM FOR A TANK. I WAS HOPING SOMEONE WITH THE SAME SETUP (SPRING AIR 305) COULD POST A PICTURE OF THERE SETUP OR GIVE ME SOME DIRECTION..
THANKS
MIKE
