RE: Great Planes Tracer
I knew I came to the rite place for advice! Thanks for the ideas. I've been considering the Tower muffler and now it sounds like a good investment. You guys are right about the plug it lasted for 2 flights and died. I've been using Cheap Tower plugs "5 for $8 or something" but I've found them to give me the best high end and idle "idle bar". If you guys say that an O,S, #8 would be better I will try it. I also plan on trying a differn't prop. My field is pretty big so a longer take off run is fine. I also plan on cleaning out the carb and installing new packings. This is all great stuff. Thanks allot! Deltatech
