RE: V7 - It Works (worked!)
Update....to any who are interested.....the servo motor failed in the HS81 servo on throttle. It will run if you start it by hand (with the gear train removed). If it stops it will not start back by itself.....and it gets very hot. I know that this is a vmax7 post...... but does anyone have a better servo than the HS81? Even metal gears would not have stopped this failure. Also I found I was missing another cyclic control linkage.....I will look up the cost and amend the LMH repair total later.
Mark
