My DD after 14 hrs.
I opted to have the fins vertical, I also cut the elverons out of the center so I can hold it there. I put some wood where I'll grab it, also the battery is way back there. If I have to change the battery it'll have to be cut out. I haven't hooked up the elverons yet, does everyone use the little guides for the pushrod on the tailfins? I also didn't use the mylar hinges, I just used hinges made from the covering, then covered the small gap with covering.
