Old 11-21-2004, 09:13 AM
Sean Plummer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Composite-ARF Extra 330L Conversion
Next the pinions must be installed onto the motor shafts. Following the the Inner demon -32 instructions, the Pinions are pressed into position using a drill press. Please note the 3mm allen cap screw is used to press the back of the shaft of the motors (Note: the label on the Hacker motors must be cut/removed to directly access the shaft as shown). Be sure to use the supplied "Green" loctite to help secure the pinions to the motor shaft.
ID:	195159   Click image for larger version
ID:	195160   Click image for larger version
ID:	195161   Click image for larger version
Sean Plummer is offline
