Old 11-22-2004, 07:14 AM
Sean Plummer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Composite-ARF Extra 330L Conversion
All hinging for the Rudder is pre-installed, simply follow the instructions.The hinges use a steel wire that is removable! and allows the rudder to be removed for transport.
The supplied rudder servo tray is designed for 2ea standard servos, I have decided to Use a single New Futaba Digital S9152 servo http://www.futaba-rc.com/servos/futm0211.html. This servo weighs 2.6oz. and has 277oz torque.
I modified the servo tray as shown, using the parts as supplied in the kit.
Be sure to use slow epoxy, and clean all surfaces with alcohol prior to gluing
Also note Large Stock Futaba servo horn. I used the Pull-Pull system as supplied in the kit. The supplied Rudder horn is glued into position as per instructions.
ID:	195505   Click image for larger version
ID:	195506   Click image for larger version
ID:	195507   Click image for larger version
Sean Plummer is offline
