RE: Direction problem?
I check the incidence and it is about 2 degrees negative.
It is the first things I correct to give about 2 degrees positive. If it is not the solution I put the step 1 inch in front of the C.G.
I cannot make a test because the lake is now frozen ,the next test in may 2005
Thanks very much for the help.
Guy
