Islandflyer- Dave always gives great advice and this is no exception, I have had 4 Patriots (2 currently-) the best set-up was Jett-50, 9x9 APC, Spring-Air retracts, and I actually used standard servos on 6V (60 oz. torque-) mine had split flaps (not necessary but fun- and heavier as Dave mentioned-) The servos you are suggesting are perfect also--
You are obviously an experienced pilot and I am pretty sure you will get hooked on the Patriot!
A side note, I would leave off the intakes for less drag and less work
although they do look pretty good--
Keep us posted!
james
