OK,
Let me spell this out a little differently. I have a four servo wing, two seperate aileron servos and two flap servos. I'd like to find a suitable connector that I could solder the appropriate extensions to so that I can connect all four servos the the receiver with a single plug. That way I don't have to sort eight different male and female connectors each time I connect the wing to the plane. I'm believe I can get away with a total of 6 pins: power, gnd, and 4 signals.
I'm sure I'm not the first person to think about this. Anyone?
Chris
ORIGINAL: Scar
You can make your own multiple connector from parts, if you wish. Dymond, Cermark and others sell the wire & ends.
Or, you could buy three "Y" connectors, and plug two into one.
Or, you could use a computer radio and a receiver with more channels, and set up with all the flaperon/spoileron/crow mixes, with plain extensions.
Good luck,
Dave Olson
ORIGINAL: ChrisAttebery
Hello,
I'm building an Ultra Stick and I'm looking for a single connector to plug the four wing servos into the receiver. Anyone know who currently makes them or the parts to solder one up?
TIA
Chris
