ORIGINAL: Pilotsmoe
ORIGINAL: skid2964
Im just trying to find out if I buy a PCM transmitter, can I ALSO use it for my planes with FM recievers. Does the PCM Tx also have some sort of "FM Mode" ?
Yes, If you buy a pcm tx, you will be able to change it to ppm mode. Check in your tx manual for how to do it
I skimmed through the manual for the Futaba 7C, is lists a "FM version" and a "PCM version" transmitter, but does not speak of switching modes ... has got me thinking I should get the FM Tx and be done with it ... I may call them and confirm the PCM unit will do FM (PPM) before I make a decision.
