Futaba T6XAs and R149DP COMPATIBLE?
I am in the processing of helping a deceased modeler's family dispose of his aircraft items. As a result of his untimely death, things are very disorganized. The problem: I have a Futaba T6XA (S) PCM 1024 CH 36 radio system with the original receiver missing. One of the airplanes has a Futaba R149DP PCM1024 CH 60 receiver. I can NOT get the xmit work with the receiver. Both the xmit and rec are high band so this should not be the problem. Is there something to activate in the xmit for the PCM receiver? I can change crystals on the Xmit and use one of the other receivers to verify a working xmit. The receiver should work - it was in his current flying model. ANY SUGGESTIONS would be appreciated. This post has been posted in the Futaba support forum.
