do you have a mount for a P-70 or would I need to fabricate something?
The answer right now is no. You and I should be able to work something out for the P70, and the coming P-60, and make it available for others as well. This is one area where I'm trying to be very flexible and work with builders as needed to adapt engines to the airframe.
For those unfamiliar with the details, I currently offer two types of turbine mounting brackets. The RAM-style works with the straps and tabs that used to come with the RAM 500. Most 54-class turbines can be mounted this way, but you may have to purchase the straps and tabs (they are available from BVM). The PST-style was made to work with the straps provided with the PST J600R.
Bruce
BTE
www.btemodels.com
