RE: Possible Conversion
Matt,
Thanks for you feed back. After my previous post, i did some more researching with a program call MotoCalc. It looks like 10 cells should be plenty. The thing I wasn't sure was the recommend prop, 14x9? Does that seem right. According to the program I'd be pulling right around 30 amps?
Once again I'm not sure if I'm running all of the numbers correctly. I think the next thing to do is get the motor, speed contral and battery pack. The owner of our LHS has been into electrics along time and offered to help me figure out the correct setup.
Jason
